Originally Posted By Twostick
Originally Posted By ProSport
Thanks for all the info everyone, it has really helped point me in the right direction. I've decided to remove the 3.55's and install the 3.23's.
And I'm gonna remove the 9.5" Dynamic street/strip converter and get me a heavy duty 11"(maybe a Hughes?). I think that combo will make me plenty happy and will save the tons of money it would take me to buy an overdrive setup.
My MP 557 cam is very smooth even right off idle so if I can cruise down the highway at less than 2500 RPM's I'll be all set.
Mine runs 2900ish at 75 MPH. 3.23's with 28" tall 275/60/15 tires.
What stall is your converter? I'd change the gears first and see how the converter likes it before I would change it.
Kevin
It's a 9.5" Dynamic, I haven't tested the flash on it as I haven't even had any sticky tires on the car yet, it's probably around 4000-4400 with my 500" motor. I'm gonna try the gears but I really think the 3.23's will make the converter slip more.
1970 Challenger, all aluminum 528 Hemi, HDK suspension, Tremec 5 speed manual
