Jeremiah, Lenco is building mine with the A833 faceplate and input shaft, and Tim Hyatt is building me an 11" clutch, 143 tooth flywheel, and long style pressure plate with counter weights. he is also installing an inspection cover as well. I have the Steel lakewood BELL, and the Robbmc starter
As soon as I get it back, I will post pictures. of my clutch setup.
