When the idle map values go inverse, start substituting tps voltage. The reason you need to go open loop at idle in some situations, is that the exhaust gas is inconsistent in oxygen content. Lambda sensor is "seeing" overlap(high O2), and than blasts of low O2 from combustion. There are a lot of ways to overcome these issues with the right system configuration.
