The tires were stock Michelin X highway treads. That had around 25,000 miles on them.. I reinstalled my Mickey Thompson 265's today....problem isn't as severe, but it still tries to do it's death dance.
I did check the balljoints, and they are a little loose. I am going to replace them and have the front end aligned. Everything else is tight. Hopefully that will cure it. Too bad the original balljoints had no way to grease them.
I know that this has 115,000 miles, but they were EASY on road miles. My 97 Ram CTD has 300,000 and a lot of dirt roads and it still drives great as does my 98 Chevy 1 ton with 245,000 miles.
Am I expecting too much for a $30,000 pickup that's led an easy life to be worn out already? I already mentioned that the worthless Hemi uses oil when it pulls hard...but that's another story!
Thanks for everyones help. Most was all good advice.
