I remounted my afcos vertical in front of the axle and they were too short, so i extended the lower mounting down an inch and gusseted it. When they were in the same position as yours, i had a similar amount of travel to you and it worked fine, the rubber bumpers dont last five minutes though.
Mick
Did you drive your ride on the street to when you had the shocks in the same position as I have them now???
-You wouldnt have a picture on how the brackets and front mounted shock look? Id like to see how you did this.
Thanks!
/Tom
