Re: Main studs or bolts
[Re: Sxrxrnr]
#1738067
02/09/15 11:00 PM
02/09/15 11:00 PM
Posts: 43,244 Bend,OR USA
Cab_Burge
Something to be aware that happened with my 512 stroker with ARP studs and Road Race Pan.
Cinching down nuts on the oil pan studs at rear main retainer I felt the torque wrench suddenly loosen as though I had stripped either the nut or the stud that was screwed into the Mancini aluminum retainer.
Pulling the pan off, I found this. The number 5 rear main stud had barely caught the oil pan and what I had felt was the pan that had been caught, suddenly slid a bit as torque was applied thereby given me that quick release that I had felt.
Yes this main stud appeared to be properly bottomed in it block hole (I pulled it out to ensure nothing else was in the hole,,,all was well).
A bit of surgery with a Dremel rounded of a bit of the nut side of the stud and all is well.
To this day not certain if was a stud problem or Road Race pan issue. Only one gasket on pan,,,no windage,,, perhaps this had something to do with it,,,places pan closer to block,,,but doubt it.
Some, not all , of ARP Mopar main stud kits come with two shorter studs in them, those two go in the back on # 5 main cap I make my own crankshaft scrapers that get glued to the block on the passenger and the half of one oil pan gasket gets glue onto the remaining oil pan surfaces and then go from there I use the scraper and stock windage trays with two more oil pan gaskets, lots of clearances between the block and oil pan with all that mess
