Probably could get away with using bolts with out any issues because it sounds like a street/strip type motor. If it were a more serious build with bigger cam, more cr, and so on I would definitely say studs only. The studs are way better because when you tap the block for threads you are going deeper into the block taking advantage of the blocks strength and allowing for a better clamp on the main caps.
