Quote: How did you gather I was referring to YOU......because I wasn't......so I don't suppose YOU are anything, other than apparently sensitive........LOL!!!
Probably coolest "swap" I have done was on a 40s Studebaker pickup. Bought a wrecked 73 Satellite 360 "donor" car. Put motor, trans, rear, rad, etc in Studebaker. Built a linkage for stock column shifter to work trans. Used mopar brake assy on firewall, throttle pedal and cable.........everything we could from Satellite. It was pretty cool. Truck looked totally restored until you opened the hood
Not sensitive. Just replying to a comment that looked like was aimed at what I said.
