Were you able to hook everything into the stock wiring for lights, ect? Did doing away with fuel injection make anything in the rest of the wiring go funky? Streetable?
Keep all the stock wiring for the lights. turn and brakes... then the engine harness is basicaly separate .. I've put chevy engines in lots of different cars/trucks for customers.. this is just your basic hot rodding
But electronic fuel injection goes into the wiring harness tho. Does leaving the connections to the injectors open cause problems?
