It is impossible to have 17.5 at the battery with 7.8-8.2 at the alternator.
Those are blue wire ign1 field terminal readings as opposed to a alt batt stud reading and they are low cuz they were taken at idle (alt ain't puttin out) whereas at a higher RPM the field terminal (blue wire circuit) voltage readings would be in the 17+ range (as would the entire electrical system) from the alt putting out what it is capable of & the bad (full fielded) reg telling/allowing it to put out all it can.
Ok he didn't specify that, but if so,
1. he is losing 1V between the alt and reg.
2.The ign side of the reg should be close to battery V or 17V,
You say the readings are low because the alt is at idle and not putting out yet his battery V is 17+ ????
