Do those voltage readings at the VR and alternator at idle indicative of charging at the max rate?
no, you took those readings at idle & the alt does not put out enough at idle which is why you have those low voltage numbers (8 ish) at the reg/alt field. At a higher RPM it will full field & put out the crazy numbers (17+ charging voltage) you mentioned earlier
