Without further testing, I wouldn't assume the problem is the regulator. A high current draw or direct short somewhere in the system will cause a perfectly good alternator and regulator to charge at the max rate.
What further testing do you suggest John?
Do those voltage readings at the VR and alternator at idle indicative of charging at the max rate?
