I did look at the bulk head connections from the firewall side and the inside and I didn't notice any discoloration or corrosion. It's harder on the b-bodies to get up that far underneath the column so I couldn't get any farther than that.
The connection looked good at the ammeter itself, will doubled check the column harness connection - thanks for the reminder.
