According to the directions, you did not install the kit correctly.
On a Mopar rear, the 5-hole bearing retainer/adjuster MUST mount 1/8" away from the housing end.
This means the wheel bearing retainer/adjuster bolts on top of the thin shim, then the (split) caliper bracket bolts on top of the retainer/adjuster.
Totally agree..........
67 Coronet 500 9.610 @ 139.20 mph
67 Coronet 500 (street car) 14.82 @ 94 mph
69 GTX (clone) - build in progress......
