Here are summit's directions that I'm working with, they're not great but you can see all the parts involved in the one exploded view
The total width added to each side is .38". The skinnier plate you see in the directions which they say to use with one piece axles only measures .13", while the outer most plate (which the directions refer to as the split mounting bracket) is .25".
Instructions
