Shcroeder racing makes all kinds of splined torsion bars typically used in Nascar as sway bars. The 1.5" dia 48 spline seems to be pretty common and they can be had in length from 30 to 50". How tough would it be to make some female splined couplers that could go in place of the factory ancor and adapted to the control arms? These come it all kinds of diameters from 7/8" up to 2"+ and either hollow or solid. Would eliminate the "Mopars cant get enough front spring rate" problem for good
http://www.schroedersteering.com/SwayBarPage.htmlhttp://www.schroedersteering.com/RateChtPDFs/1-12barchart.pdf
