Quote: I have the borgeson box - love it. I do need to do the shimming to it as mine is a little off - but the driving experience is quite good.
What was the reason that you had to do a bit of shimming. Could you explain the process to do so. I am dealing with toe alignment issues since installing Borgeson and about to install a replacement unit to find if issues resolve.
If unsuccessful may too have to consider shimming.
