Tim went thru the entire progression on his red Valiant. He started off with a stock manual box, switched to a fast ratio manual box, then finally ended up with PS.
With big tires up front, and a bunch of caster and camber dialed in for handling, the manual box is just too much work to drive on a regular basis.
