Edit: And as I've been slowly figuring out... No one makes an 18 x 9" wheel. Literally, every wheel manufacturer's page I go to skips straight from 8.5" to 9.5".
SVE Drift wheels on my car, they cost $150-$160 each. Sold for Mustangs... by Late Model Restoration. I mixed and matched years to get the size and offset I wanted.
Fits 1994-2004 Model Year Mustang
Offset: +24mm
Backspacing: 5.95
Lug Pattern: 5x114.3
Weight: 24 lbs
Offset: +22mm
Backspacing: 6.36
Weight: 25 lbs
If you need deeper offset, then the 2005-2014 Mustang is:
18x9"
Offset - +35mm
Backspacing - 6.38"
Weight - 23lbs
18x10"
Offset - +43mm
Backspacing - 7.20"
Weight - 24lbs
-Michael
I think I may need to go this route with the 18 x 9's and the +24mm and +35mm offsets, but I don't think I'm seeing them on AMR's website.
You have to be specific about the year on their site. Some wheels are only available for certain years. But you want 94-04 FRONTS for your rears and 05+ fronts for your fronts.
Mopar to the bone!!!
