Re: 275 Series Tires, A-bodies, and Offset Shackles
[Re: Uhcoog1]
#1671586
09/20/14 04:06 AM
09/20/14 04:06 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
If you are unsure of spacers, do it right and do one of the following: 1. Run different offset front and rear 2. Run a wider rear that takes the same offset as the front
I'm leaning towards running different offset wheel although I do like the idea of rotating tires. Another rear end is not an option. I guess you could rotate them by dismounting them and placing them on another wheel if all the wheel widths are the same.
The deal Tomswheels offered you is a smoking good deal.
Tomswheels set up gets my vote. Run the +24 in rear with offset shackles and a 1/4" steel spacer, and the +30 up front (going to be tight on the fender depending on your alignment and ride height).
There is zero issue with a 1/4" or smaller spacer.
Offset shackles are not an option at this point. Rear end is already installed and I can't move in perches. To use a max of a 1/4" spacer I have to find a wheel that offers a +30mm offset for the fronts and about a +13-14mm offset for the rears. Although, I have been looking at that site.
So far the wheel that may fit my description on Summit is: http://www.summitracing.com/parts/dgw-22786/overview/ http://www.summitracing.com/parts/dgw-22783/overview/
The Enkei PF01 is offered in +15mm, +35mm, and +45mm +with the 9.5" wide wheels. I'm not sure if they'll fit even though a 245/40/18 will still mount to them. I heard the center bores (at least for the RPF1's) have to be bored out to 73mm as they're tapered.
http://www.summitracing.com/search/brand...mp;autoview=SKU
Entire Thread
MuuMuu101
09/16/14 02:17 AM
MuuMuu101
09/16/14 02:18 AM
autoxcuda
09/16/14 04:36 AM
MuuMuu101
09/16/14 04:47 AM
autoxcuda
09/16/14 04:55 AM
MuuMuu101
09/16/14 05:01 AM
autoxcuda
09/16/14 05:17 AM
MuuMuu101
09/16/14 05:21 AM
72Swinger
09/16/14 05:35 AM
MuuMuu101
09/16/14 05:36 AM
68cuda440
09/16/14 05:55 AM
MuuMuu101
09/16/14 05:58 AM
68cuda440
09/16/14 06:03 AM
68cuda440
09/16/14 05:42 AM
DoctorDiff
09/16/14 06:02 AM
MuuMuu101
09/16/14 08:31 AM
Tomswheels
09/17/14 12:20 AM
MuuMuu101
09/17/14 12:28 AM
Tomswheels
09/17/14 01:20 AM
MuuMuu101
09/17/14 03:45 AM
72Swinger
09/17/14 04:21 AM
MuuMuu101
09/17/14 04:43 AM
72Swinger
09/17/14 04:47 AM
MuuMuu101
09/17/14 04:56 AM
72Swinger
09/17/14 05:03 AM
MuuMuu101
09/17/14 05:09 AM
MuuMuu101
09/17/14 05:29 AM
72Swinger
09/17/14 05:36 AM
Tomswheels
09/17/14 05:33 AM
MuuMuu101
09/17/14 07:05 AM
Tomswheels
09/17/14 03:59 PM
MuuMuu101
09/18/14 02:45 AM
Tomswheels
09/18/14 03:54 AM
MuuMuu101
09/18/14 04:00 AM
MuuMuu101
09/18/14 04:46 AM
MuuMuu101
09/18/14 04:48 AM
RylisPro
09/18/14 05:01 AM
MuuMuu101
09/18/14 05:12 AM
RylisPro
09/18/14 05:36 AM
MuuMuu101
09/18/14 05:43 AM
RylisPro
09/18/14 05:55 AM
MuuMuu101
09/18/14 06:08 AM
blown340
09/18/14 06:48 AM
MuuMuu101
09/18/14 07:57 AM
Uhcoog1
09/18/14 02:12 PM
MuuMuu101
09/20/14 08:06 AM
Tomswheels
09/20/14 06:02 PM
MuuMuu101
09/20/14 10:15 PM
MuuMuu101
09/18/14 04:49 AM
MuuMuu101
09/18/14 04:50 AM
MuuMuu101
09/18/14 04:51 AM
MuuMuu101
09/27/14 02:16 AM
MuuMuu101
09/27/14 02:17 AM
MuuMuu101
09/27/14 02:19 AM
MuuMuu101
09/27/14 02:21 AM
72Swinger
09/27/14 02:49 AM
MuuMuu101
09/27/14 02:58 AM
72Swinger
09/27/14 03:02 AM
MuuMuu101
09/27/14 03:43 AM
MuuMuu101
09/27/14 03:44 AM
MuuMuu101
09/27/14 03:44 AM
72Swinger
09/27/14 04:05 AM
MuuMuu101
09/27/14 04:32 AM
72Swinger
09/27/14 04:47 AM
MuuMuu101
09/27/14 05:12 AM
Supercuda
09/27/14 05:29 AM
MuuMuu101
09/27/14 05:33 AM
Supercuda
09/27/14 05:35 AM
MuuMuu101
09/27/14 06:07 AM
Uhcoog1
09/27/14 01:38 PM
MuuMuu101
09/27/14 05:57 PM
OzHemi
09/28/14 04:52 PM
buconine
10/10/14 01:57 PM
MuuMuu101
10/11/14 05:11 AM
MuuMuu101
10/12/14 08:55 PM
RylisPro
10/12/14 10:22 PM
MuuMuu101
10/12/14 10:23 PM
RylisPro
10/12/14 10:31 PM
MuuMuu101
10/12/14 10:46 PM
72Swinger
10/12/14 11:17 PM
MuuMuu101
10/12/14 11:22 PM
MuuMuu101
10/12/14 11:51 PM
MuuMuu101
10/13/14 05:56 AM
Tomswheels
10/13/14 06:39 AM
MuuMuu101
10/13/14 06:47 AM
Tomswheels
10/13/14 08:13 AM
MuuMuu101
10/13/14 08:18 AM
Tomswheels
10/30/14 06:28 PM
MuuMuu101
10/31/14 06:02 AM
72Swinger
10/31/14 09:11 AM
Tomswheels
10/31/14 03:21 PM
72Swinger
10/31/14 05:26 PM
Trojmn
11/01/14 04:40 AM
Tomswheels
11/01/14 05:25 AM
buconine
11/02/14 05:29 PM
MuuMuu101
11/02/14 07:19 PM
Tomswheels
11/02/14 08:07 PM
buconine
11/03/14 01:40 AM
MuuMuu101
11/21/14 06:11 AM
Trojmn
11/22/14 02:12 AM
Tomswheels
11/22/14 02:46 AM
Uhcoog1
11/22/14 03:59 PM
Tomswheels
11/23/14 02:41 AM
RylisPro
10/31/14 02:06 PM
68cuda440
11/21/14 06:28 AM
MuuMuu101
11/21/14 06:36 AM
MuuMuu101
11/24/14 04:53 AM
72Swinger
11/24/14 04:59 AM
MuuMuu101
11/24/14 05:03 AM
72Swinger
11/24/14 05:08 AM
MuuMuu101
11/24/14 05:15 AM
72Swinger
11/24/14 05:25 AM
MuuMuu101
11/25/14 04:12 AM
72Swinger
11/25/14 05:26 AM
MuuMuu101
11/25/14 05:36 AM
72Swinger
09/27/14 05:45 AM
MuuMuu101
09/27/14 05:57 AM
68cuda440
09/16/14 05:29 AM
MuuMuu101
09/16/14 05:35 AM
72Swinger
09/16/14 06:22 AM
autoxcuda
09/16/14 07:19 AM
72Swinger
09/16/14 07:41 AM
MuuMuu101
09/20/14 07:53 AM
MuuMuu101
10/04/14 07:13 PM
MuuMuu101
11/27/14 04:01 AM
MuuMuu101
11/28/14 10:42 PM
Tomswheels
12/07/14 09:12 PM
MuuMuu101
12/07/14 09:16 PM
Tomswheels
12/07/14 10:02 PM
autoxcuda
12/07/14 10:08 PM
72Swinger
12/07/14 10:16 PM
Tomswheels
12/08/14 12:42 AM
autoxcuda
12/08/14 12:53 AM
68cuda440
12/08/14 05:21 AM
Tomswheels
12/08/14 05:24 AM
72Swinger
12/08/14 05:33 AM
Tomswheels
12/09/14 12:40 AM
Tomswheels
12/09/14 12:40 AM
Tomswheels
12/09/14 12:42 AM
68cuda440
12/08/14 05:09 AM
MuuMuu101
12/08/14 05:47 AM
72Swinger
12/08/14 05:59 AM
MuuMuu101
12/08/14 06:07 AM
MuuMuu101
12/09/14 01:39 AM
RylisPro
12/09/14 01:55 AM
MuuMuu101
12/09/14 02:10 AM
moparpollack
12/09/14 02:40 AM
MuuMuu101
12/09/14 02:41 AM
MuuMuu101
12/16/14 02:29 AM
72Swinger
12/16/14 02:35 AM
MuuMuu101
12/16/14 02:44 AM
