Re: 275 Series Tires, A-bodies, and Offset Shackles
[Re: autoxcuda]
#1671544
09/16/14 01:42 AM
09/16/14 01:42 AM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
I'm not intimately familiar with Dr Diff rear rotors, but are they thicker where they mount to the axle than the drums you took off that 8 3/4 ?
If so, how much? If so, they makes you rear a little wider too.
Not by much. The outside face of the rotor I have in the rear sits just below flush on the center register on the axle, so yes it is thicker than the stock drum.
The front kit he has is the same as mine. It is like taking a Cordoba hub and cutting the rotor off. Then add the rotor thickness. So it ends up a bit wider than the Cordoba brakes. I think Cass designed it to work with the late model Mustang wheel offsets. To get the same size front and rear and get them to sit right, like a 17x8 wheel for example, you would probably have to go with a small 1/2" spacer on the rear.
I would just ask Cass (Dr Diff), he sells the kits and knows what works.
-Michael
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
Entire Thread
MuuMuu101
09/16/14 02:17 AM
MuuMuu101
09/16/14 02:18 AM
autoxcuda
09/16/14 04:36 AM
MuuMuu101
09/16/14 04:47 AM
autoxcuda
09/16/14 04:55 AM
MuuMuu101
09/16/14 05:01 AM
autoxcuda
09/16/14 05:17 AM
MuuMuu101
09/16/14 05:21 AM
72Swinger
09/16/14 05:35 AM
MuuMuu101
09/16/14 05:36 AM
68cuda440
09/16/14 05:55 AM
MuuMuu101
09/16/14 05:58 AM
68cuda440
09/16/14 06:03 AM
68cuda440
09/16/14 05:42 AM
DoctorDiff
09/16/14 06:02 AM
MuuMuu101
09/16/14 08:31 AM
Tomswheels
09/17/14 12:20 AM
MuuMuu101
09/17/14 12:28 AM
Tomswheels
09/17/14 01:20 AM
MuuMuu101
09/17/14 03:45 AM
72Swinger
09/17/14 04:21 AM
MuuMuu101
09/17/14 04:43 AM
72Swinger
09/17/14 04:47 AM
MuuMuu101
09/17/14 04:56 AM
72Swinger
09/17/14 05:03 AM
MuuMuu101
09/17/14 05:09 AM
MuuMuu101
09/17/14 05:29 AM
72Swinger
09/17/14 05:36 AM
Tomswheels
09/17/14 05:33 AM
MuuMuu101
09/17/14 07:05 AM
Tomswheels
09/17/14 03:59 PM
MuuMuu101
09/18/14 02:45 AM
Tomswheels
09/18/14 03:54 AM
MuuMuu101
09/18/14 04:00 AM
MuuMuu101
09/18/14 04:46 AM
MuuMuu101
09/18/14 04:48 AM
RylisPro
09/18/14 05:01 AM
MuuMuu101
09/18/14 05:12 AM
RylisPro
09/18/14 05:36 AM
MuuMuu101
09/18/14 05:43 AM
RylisPro
09/18/14 05:55 AM
MuuMuu101
09/18/14 06:08 AM
blown340
09/18/14 06:48 AM
MuuMuu101
09/18/14 07:57 AM
Uhcoog1
09/18/14 02:12 PM
MuuMuu101
09/20/14 08:06 AM
Tomswheels
09/20/14 06:02 PM
MuuMuu101
09/20/14 10:15 PM
MuuMuu101
09/18/14 04:49 AM
MuuMuu101
09/18/14 04:50 AM
MuuMuu101
09/18/14 04:51 AM
MuuMuu101
09/27/14 02:16 AM
MuuMuu101
09/27/14 02:17 AM
MuuMuu101
09/27/14 02:19 AM
MuuMuu101
09/27/14 02:21 AM
72Swinger
09/27/14 02:49 AM
MuuMuu101
09/27/14 02:58 AM
72Swinger
09/27/14 03:02 AM
MuuMuu101
09/27/14 03:43 AM
MuuMuu101
09/27/14 03:44 AM
MuuMuu101
09/27/14 03:44 AM
72Swinger
09/27/14 04:05 AM
MuuMuu101
09/27/14 04:32 AM
72Swinger
09/27/14 04:47 AM
MuuMuu101
09/27/14 05:12 AM
Supercuda
09/27/14 05:29 AM
MuuMuu101
09/27/14 05:33 AM
Supercuda
09/27/14 05:35 AM
MuuMuu101
09/27/14 06:07 AM
Uhcoog1
09/27/14 01:38 PM
MuuMuu101
09/27/14 05:57 PM
OzHemi
09/28/14 04:52 PM
buconine
10/10/14 01:57 PM
MuuMuu101
10/11/14 05:11 AM
MuuMuu101
10/12/14 08:55 PM
RylisPro
10/12/14 10:22 PM
MuuMuu101
10/12/14 10:23 PM
RylisPro
10/12/14 10:31 PM
MuuMuu101
10/12/14 10:46 PM
72Swinger
10/12/14 11:17 PM
MuuMuu101
10/12/14 11:22 PM
MuuMuu101
10/12/14 11:51 PM
MuuMuu101
10/13/14 05:56 AM
Tomswheels
10/13/14 06:39 AM
MuuMuu101
10/13/14 06:47 AM
Tomswheels
10/13/14 08:13 AM
MuuMuu101
10/13/14 08:18 AM
Tomswheels
10/30/14 06:28 PM
MuuMuu101
10/31/14 06:02 AM
72Swinger
10/31/14 09:11 AM
Tomswheels
10/31/14 03:21 PM
72Swinger
10/31/14 05:26 PM
Trojmn
11/01/14 04:40 AM
Tomswheels
11/01/14 05:25 AM
buconine
11/02/14 05:29 PM
MuuMuu101
11/02/14 07:19 PM
Tomswheels
11/02/14 08:07 PM
buconine
11/03/14 01:40 AM
MuuMuu101
11/21/14 06:11 AM
Trojmn
11/22/14 02:12 AM
Tomswheels
11/22/14 02:46 AM
Uhcoog1
11/22/14 03:59 PM
Tomswheels
11/23/14 02:41 AM
RylisPro
10/31/14 02:06 PM
68cuda440
11/21/14 06:28 AM
MuuMuu101
11/21/14 06:36 AM
MuuMuu101
11/24/14 04:53 AM
72Swinger
11/24/14 04:59 AM
MuuMuu101
11/24/14 05:03 AM
72Swinger
11/24/14 05:08 AM
MuuMuu101
11/24/14 05:15 AM
72Swinger
11/24/14 05:25 AM
MuuMuu101
11/25/14 04:12 AM
72Swinger
11/25/14 05:26 AM
MuuMuu101
11/25/14 05:36 AM
72Swinger
09/27/14 05:45 AM
MuuMuu101
09/27/14 05:57 AM
68cuda440
09/16/14 05:29 AM
MuuMuu101
09/16/14 05:35 AM
72Swinger
09/16/14 06:22 AM
autoxcuda
09/16/14 07:19 AM
72Swinger
09/16/14 07:41 AM
MuuMuu101
09/20/14 07:53 AM
MuuMuu101
10/04/14 07:13 PM
MuuMuu101
11/27/14 04:01 AM
MuuMuu101
11/28/14 10:42 PM
Tomswheels
12/07/14 09:12 PM
MuuMuu101
12/07/14 09:16 PM
Tomswheels
12/07/14 10:02 PM
autoxcuda
12/07/14 10:08 PM
72Swinger
12/07/14 10:16 PM
Tomswheels
12/08/14 12:42 AM
autoxcuda
12/08/14 12:53 AM
68cuda440
12/08/14 05:21 AM
Tomswheels
12/08/14 05:24 AM
72Swinger
12/08/14 05:33 AM
Tomswheels
12/09/14 12:40 AM
Tomswheels
12/09/14 12:40 AM
Tomswheels
12/09/14 12:42 AM
68cuda440
12/08/14 05:09 AM
MuuMuu101
12/08/14 05:47 AM
72Swinger
12/08/14 05:59 AM
MuuMuu101
12/08/14 06:07 AM
MuuMuu101
12/09/14 01:39 AM
RylisPro
12/09/14 01:55 AM
MuuMuu101
12/09/14 02:10 AM
moparpollack
12/09/14 02:40 AM
MuuMuu101
12/09/14 02:41 AM
MuuMuu101
12/16/14 02:29 AM
72Swinger
12/16/14 02:35 AM
MuuMuu101
12/16/14 02:44 AM
