Quote: small block Mopars and Boost is not the best plan--4 bolts per cylinder on the head is not good for forced induction--poor idea IMO Run from that go big block
You do know race blocks are 6 bolt. And any motor you build at this hp level needs to be a aftermarket block, big or small.
Brett Miller W9 cnc'd heads STR Chassis fabraction
