If your willing to use EFI, then the Big B1 with twin 88's or 91's would do what you need, under 15psi I think. It might be hard to only run a 5 when it would be close'r to 3's
Or an F2 should feed it if you stay carb. But I would call Procharger directly to get there recomendation.
