If the transmission slopes 2 degrees downward toward the rear and the pinion slopes 4.5 degrees downward toward the front, you need to raise the front of the pinion 4.5 degrees to yield a 2 degree negative pinion angle.
In other words, the thick part of the 4.5 degree wedge must face the front of the car.
