Quote: You have an idle circuit issue. I am assuming this is a 3 circuit carb. If you used a set if 2 circuit gaskets it will block off the idle feeds, etc. make sure that the gasket has 4 holes at the top on each side. One big and three little.
I never thought about the wrong gaskets being on it
Gee I thought that I said that about 5 post before AJs
If the MODS did their job I would not be hitting the notify MOD button. LOL
