I took the carb off and looked and there was no transfer slot showing at all on the back. Do I set the slots square on the back then put it back on and see if that helps?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
