Quote: You have an idle circuit issue. I am assuming this is a 3 circuit carb. If you used a set if 2 circuit gaskets it will block off the idle feeds, etc. make sure that the gasket has 4 holes at the top on each side. One big and three little.
I never thought about the wrong gaskets being on it
I will check that.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
