We had a problem with a 426 crate HEMI shutting off while driving down the road. It has a FAST EZ dual TB setup on it. The distributor wire has to be very well isolated from interference and the power wire must go to the battery itself and not to the stud on the starter relay. The dyno tuner wasn't fond of the lack of tunability with the EZ.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
