After looking over the Electromotive site, I think the TEC3R should be highly considered.
The Beditor has been unlocked with the control.zip file as per Edelbrocks suggestion.
One of the biggest PITA's of the Edelbrock system is the data screen keeps locking up on the laptop. When it does you can't close it with the X in the upper right hand corner, you have to right click from the task bar then close and then reopen and it does it all over again within seconds. It is a common problem with their software and they are aware of it.
