Quote: the Molnar H beam in a 6.250 length with standard Chevy pin weights 512g with 3/8 arp2000 bolts. can I use the 3/8 bolts in this combo or should I be using the 7/16 bolt. looks like the bigger bolt adds a lot of weight. pistons will be between 400-450G.
If you go to a Mopar spec piston, then you won't have to use that long rod....
