talk to the people at buechelon BPE,THEY can fix you up on everything you need,i dont remember the part # of brackets,but there are different brackets for a number of water pump housings,they will need the # off yours.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
