csk thanks for the picture. I see you used the bouchillon rear bracket, did you use part number(BPE4700)?
What bracket did you use for the front of the a/c compressor?
also what compressor did you use?
That little bent bracket on the back, i have that, however i'm not sure what it's supposed to go to, can you take a picture just like that but zoomed out so i can see the power steering setup better?
