get the 1.14 from FF and be done...
The only size in that range I see listed from FF for the A body is 1.12 and 1.18, I am having trouble deciding between the two. One day I think 1.12 would be OK, others I think 1.18 is the correct choice. Car has sub frame connectors and torque boxes. No cage. 255/40-18 front tires. I plan on welding the K-frame and adding the LCA stiffening plates. I read an opinion several years back that the 1.18 would be too stiff a bar for a car without a cage. Car is mostly meant for the street. The car has a 440.
Comments or opinions?
-Michael
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
