I have a '68 Fury III that won't start. Bought it in the U.S. and shipped it to the USVI. Was PERFECT on the continent. Arrived here and has had nothing but problems. I sense someone along the shipping trail pulled a Ferris Bueller on me, but I'm opting for the benefit of the doubt.
Issue: Won't start. Turns over, fuel pressure is fine, timing is correct. Very faint spark in the plugs and distributor. Has acted as if it wasn't getting enough fuel. Now acts like it's not getting enough spark to ignite the fuel. We are absolutely stumped.
Here's what we've done so far:
Changed:
- Battery
- Plugs
- Condensers
- Ballast resistor
- Coil
- Fuel filters (3x - shippers ran it to fumes and it sucked up a bunch of tank muck)
Rebuilt aftermarket Edelbrock carb (thought the floats might be the issue)
Going to try the voltage regulator next, but frankly not confident.
Anyone got any ideas out there? This is crazy!
