Re: Just Won't Start - Completely Stumped
[Re: Viv]
#1521851
10/23/13 09:23 AM
10/23/13 09:23 AM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
Did you change the points?The VR has nothing to do with it running unless the battery is dead.If it sucked junk from the tank Id clean the tank and carb.Try points and setting them to .017.That and check the cap and rotor as it also could be bad from dampness.Coil lead could be a problem also.Rocky
Chrysler Firepower
[Re: Wedgeman]
#1521869
10/23/13 10:56 AM
10/23/13 10:56 AM
RapidRobert
welcome aboard! We WILL solve this . Take off the coil secondary wire (dist end) & hold it 1/4" from the intake (ground). Take off all wires from the coil positive/neg primary terminals. Jump 12V from the batt to the coil positive pri terminal. With a jumper wire with alligator clips connect one end to the coil neg pri terminal & with the other end make/break contact to ground & see if the coil secondary wire sparks. If good then remove the jumper wire from the neg pri terminal & hookup the thin dist black wire & open/close the points with a screwdriver & see if the coil secondary wire makes sparks
