Page 1 of 3 1 2 3
Just Won't Start - Completely Stumped #1521850
10/23/13 09:13 AM
10/23/13 09:13 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
I have a '68 Fury III that won't start. Bought it in the U.S. and shipped it to the USVI. Was PERFECT on the continent. Arrived here and has had nothing but problems. I sense someone along the shipping trail pulled a Ferris Bueller on me, but I'm opting for the benefit of the doubt.
Issue: Won't start. Turns over, fuel pressure is fine, timing is correct. Very faint spark in the plugs and distributor. Has acted as if it wasn't getting enough fuel. Now acts like it's not getting enough spark to ignite the fuel. We are absolutely stumped.
Here's what we've done so far:
Changed:
- Battery
- Plugs
- Condensers
- Ballast resistor
- Coil
- Fuel filters (3x - shippers ran it to fumes and it sucked up a bunch of tank muck)
Rebuilt aftermarket Edelbrock carb (thought the floats might be the issue)
Going to try the voltage regulator next, but frankly not confident.
Anyone got any ideas out there? This is crazy!
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521851
10/23/13 09:23 AM
10/23/13 09:23 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Did you change the points?The VR has nothing to do with it running unless the battery is dead.If it sucked junk from the tank Id clean the tank and carb.Try points and setting them to .017.That and check the cap and rotor as it also could be bad from dampness.Coil lead could be a problem also.Rocky
Chrysler Firepower
Re: Just Won't Start - Completely Stumped [Re: therocks] #1521852
10/23/13 09:38 AM
10/23/13 09:38 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
Rebuilt carb, so it's been cleaned. Changed the coil - lead isn't a problem. Will change points. Changed everything else, so why not? lol Cap and rotor are fine. Checked and cleaned up on arrival.
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521853
10/23/13 09:40 AM
10/23/13 09:40 AM
Hermiston Oregon
mopar_leaner Offline
Hermiston Oregon
how do the plug wires look?
( it takes a Mopar, to beat a Mopar!
email me at moparleaner@gmail.com )
Re: Just Won't Start - Completely Stumped [Re: mopar_leaner] #1521854
10/23/13 09:53 AM
10/23/13 09:53 AM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
Make sure the spark at the plug is blue, if it is orange bad coil
Re: Just Won't Start - Completely Stumped [Re: mopar_leaner] #1521855
10/23/13 09:53 AM
10/23/13 09:53 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
Plug wires are clean.
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521856
10/23/13 09:54 AM
10/23/13 09:54 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did you try bypassing the ballast resistor???
Then try a hot wire from batter + to out side of ballast or + side of coil and see if it runs.
Re: Just Won't Start - Completely Stumped [Re: Dodgem] #1521857
10/23/13 10:01 AM
10/23/13 10:01 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
Will try bypassing ballast resistor.
Will a bad condenser cause reduced spark in the distributor?
Spark in plugs is orange.
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521858
10/23/13 10:13 AM
10/23/13 10:13 AM
W
Wedgeman Offline
Wedgeman  Offline
W
If spark is orange, the car will never start !
The coil is not giving enough current to light up the fuel, happens even with new coils......
And you should have 7 volts at the + terminal of the coil with the key at ignition
Dan
Re: Just Won't Start - Completely Stumped [Re: Wedgeman] #1521859
10/23/13 10:35 AM
10/23/13 10:35 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
It is a new coil. Should i replace it? The spark at spark plug is also very light or no spark at times.
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521860
10/23/13 10:38 AM
10/23/13 10:38 AM
W
Wedgeman Offline
Wedgeman  Offline
W
If the spark is orange, even new coil, replace it, the coil is faulty
Dan
Re: Just Won't Start - Completely Stumped [Re: Wedgeman] #1521861
10/23/13 10:39 AM
10/23/13 10:39 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Have you tried to run a wire from thebattery to the + terminal of the coil ?
Re: Just Won't Start - Completely Stumped [Re: Dodgem] #1521862
10/23/13 10:40 AM
10/23/13 10:40 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
I tried jumping the ballast and the coil and still didn't start?
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521863
10/23/13 10:42 AM
10/23/13 10:42 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Bad coil....what brand is it ?
Re: Just Won't Start - Completely Stumped [Re: Wedgeman] #1521864
10/23/13 10:49 AM
10/23/13 10:49 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
Now i am thinking plug wires but I don't understand why it would run fine one day and the next not start. Have good spark at points.
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521865
10/23/13 10:50 AM
10/23/13 10:50 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Have you tried a battery charger hooked up while cranking the motor even though it is a new battery?
I know you said new plugs, are they still in good shape after all this cranking?
Re: Just Won't Start - Completely Stumped [Re: Wedgeman] #1521866
10/23/13 10:51 AM
10/23/13 10:51 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
BWD P-Series coil
Re: Just Won't Start - Completely Stumped [Re: Viv] #1521867
10/23/13 10:54 AM
10/23/13 10:54 AM
W
Wedgeman Offline
Wedgeman  Offline
W
Change coil, happened to me before too.....
and check for spark color
Re: Just Won't Start - Completely Stumped [Re: Challenger 1] #1521868
10/23/13 10:55 AM
10/23/13 10:55 AM
U.S. Virgin Islands
V
Viv Offline OP
Viv  Offline OP
V
U.S. Virgin Islands
Don't have battery charger but have had another car jumping while starting. I know it may not give full jumping charge as a charger would but the best I have. The plugs look good and have cleaned them a couple of times even though that may not mean anything.
Re: Just Won't Start - Completely Stumped [Re: Wedgeman] #1521869
10/23/13 10:56 AM
10/23/13 10:56 AM
welcome aboard! We WILL solve this . Take off the coil secondary wire (dist end) & hold it 1/4" from the intake (ground). Take off all wires from the coil positive/neg primary terminals. Jump 12V from the batt to the coil positive pri terminal. With a jumper wire with alligator clips connect one end to the coil neg pri terminal & with the other end make/break contact to ground & see if the coil secondary wire sparks. If good then remove the jumper wire from the neg pri terminal & hookup the thin dist black wire & open/close the points with a screwdriver & see if the coil secondary wire makes sparks
Page 1 of 3 1 2 3
