My suggestion Remove plugs and inject Oil in each cly and leave plugs out for at least 45 minutes install new plugs and or cleaned and dried ones crank engine and make sure choke is working if flood3ed hold on floor with choke open It is possible you are working with a badly flooded engine and gas washed cly walls loosing compression. No chance the timing chain jumped?
