Why won't they work?
ok i will rephrase my reply. i know of 5 different people that tried 950hp mecanical carbs and none of them could get them to work. plus my self 4 were on cast crossrams 2 were on sheetmetal intakes.
probably because it way to much, I have seen many 750 double pump carbs on tunnel rams.not to mention dominators on applications that need them.
950's will work if they are vacuum secondaries.
I must be missing something? what does the vac secondary have to do with it? you are only on that circuit for a second.
