Quote: When I try to free rev it, it will go to about 4000 rpm and stumble momentarily and then jump up.
The reason I ask if it will free rev is that will eliminate the drive line/conv... it still has the problem but less and at a different rpm.. load just makes it worse.... have you sprayed the intake for vac leaks
