The radiator will cool it down first then get it even cooler going through the external one. With a cooler that size it should work fine. Do you have a deep pan? Check with a trans temp gauge.
The trans does have a deep pan. Where do I install a sensor for a gauge? This is an A500 in a third gen b body.
Just asking- If an engine is runnIng 180* what is the temp of the fluid going through the bottom of the radiator? How much does it drop the temp of the trans fluid in a normal situation?
The reason for the questions is because I am installing a small stall converter so I know it is going to generate a little more heat.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
