Quote: Guys...I'm no expert..but I think after one burnout if you took the wheel off it would be out of balance again..just my thoughts...
If you burn the rubber off all the way around it should still be in balance... if it were to bounce in the burnout it would burn the rubber off at different areas more than other areas... thats when I use to see the most irregular wear on my tires when I didnt balance and that got progressively worse with each burnout... I balance but you guys can do what ever works for you.. I dont say my way is the right way... but I see the pros doing it all the time and it works for them
