I may be off base here but I would think that the hot idling dieing problem is from the combo of E10/heat not a fuel delivery inadequacy that an elec pump would fix. EDIT could you plumb in a can of race gas or any available fuel that has no ethanol in it to the pump inlet & see if the problem goes away? But if an elec pump will pressurize the ethanol & solve this I stand corrected
IDK the answer, just taking all the suggestions I can get and passing them on to my mechanic......
2016 Diesel Ram 3500 Mason Dump 1971 Challenger 2013 Jeep Wrangler 1979 Dodge Ram Power Wagon 400 Mini Pumper My other car is a Fire Truck.
