Sure bro. Dirt in the idle passages & the idle system has the smallest passages & are the easiest to plug up. Starting fluid cleans em. The only thing that makes me think that this might be something else as in heat related with the fuel is that it only happens when hot but blasting the 2 holes clean is easy to do & has happened to me several times on my eddy 1406, it would die at idle. Had to blast it several times in a month then I put on a new fuel filter & been good for months now. E10 (ethanol) corn gas will do it but I'm assuming you have not changed gas stations
