I may be off base here but I would think that the hot idling dieing problem is from the combo of E10/heat not a fuel delivery inadequacy that an elec pump would fix. EDIT could you plumb in a can of race gas or any available fuel that has no ethanol in it to the pump inlet & see if the problem goes away? But if an elec pump will pressurize the ethanol & solve this I stand corrected
