Quote: All other rockers look good, no slop, no signs of heat.
I'm looking at getting a set of H-S's and not looking back. My question is is it worth the nominal hit in power to drop down to 1.5's... The cam was ground with 1.6's in mind. It is also not a fast ramp design.
If you have 1.6 now I'd stay with them... just make sure the springs are good
