Re: oil additive question
[Re: 62maxwgn]
#143875
11/02/08 12:15 PM
11/02/08 12:15 PM
Posts: 21,844 Kirkland, Washington
Pacnorthcuda
If you do your homework ,you can find "GOOD" oil and don't need addatives.This subject has been beat to death on a few other forums.
True, but one must take into account that oils are constantly being reformulated and levels of zinc and phosphourus are changing. Oil companies can (and do) make changes 'between' the rolling of the API or diesel specs--So a SL,SM, CI or CJ oil that tests ok today may not have the same levels next month. Its a real risk that is part of the problem. I would not however, include some brands such as Brad Penn, Redline, Amsoil etc that are specifically marketed to us and the zinc issue discussed within their marketing programs.
