In the last year I have found about 60 qts of left over older formula SJ and SL at various stores.
So tonite I was in a Walmart checking the back of the shelves. I noticed they carry Royal Purple, it has a SL rating. The Mobil 1 'High Mileage' oil also has a SL rating, not SM like other Mobil 1 formulas. Anyone know the Zn-Ph ppm of these two?
I prefer not to run diesel oil because of too much detergent and the racing oil has too little, requiring more frequent oil changes. Something I can get locally off the shelf would be great if High Mileage Mobil 1 has enough ZDDP.
The straight 30wt Castrol also has a SL rating, other 30wt oils I have seen in the past is still SL oil.
