take the hot wire off the batt while it is running....if it shuts off the alt is bad
if it stays running its a low or bad batt
use the multi meter to check for 14 volts while its running at the batt...may be a little more than that if its got a low batt and the alt is chargeing at the time of the reading
have the alt tested at a parts store before replacing it to be sure
