Everyones budget and results they would be happy with are different. For a torque engine that WILL run on pump gas 10to 1 comp isn't going to work, a dual pattern cam is a poor idea and more cubes is the best choice if you really want torque and pump gas in a truck. Magnum heads on a stock LA 360 is fine,if you don't waste lots of time finding a set that are usable,a stock or 252 high energy cam is a fine choice.
