Quote: The tool is trick, 200 bucks is a bit steep
, I'd suggest a plumbing T, a long threaded plumbing nipple to screw into the T for a handle, a sleeve inside to protect the rocker shaft from the inside threads on the T & the only slightly harder part is welding a pair of tabs on the T to contact the retainer
